Anoka, MN–Hoffman announces the H2OMIT™ Thermoelectric Dehumidifier and UL 4X Listed Vent Drain, designed to protect sensitive electrical and electronic equipment from damage caused by condensation. The thermoelectric dehumidifier removes moisture from the air within an enclosure, continuously controlling condensation formation on components and the enclosure walls. As this moisture collects and pools, it exits through the one-way vent drain, providing a comprehensive moisture removal and elimination solution. Both devices are easily installed or retrofitted in metallic and non-metallic enclosures, minimizing condensation damage and maximizing component functional life–even in the most demanding industries and applications.
With Hoffman’s H2OMIT Vent Drain, condensed moisture exits the enclosure using the force of gravity, and re-entry of water and outside contaminants is blocked with a mechanical shut-off. Additionally, the UL 4X Listed vent drain functions as an air pressure equalizer, reducing the harmful effects of temperature-induced vacuums that could pull water and moisture into the enclosure.
The vent drain, which is approximately 2-inches long and 1.25-inches in diameter, is available in a corrosion-resistant non-metallic polyester material, or encased in 304 stainless steel. Non-metallic vent drains provide users a cost-effective and certified solution for removing liquids from mild steel, aluminum, non-metallic and stainless steel enclosures. The 304 stainless steel encased vent drain is well suited for stainless steel enclosures, providing the aesthetics and robust performance that these applications require.
Filed Under: Cabinets • enclosures • control panels, Safety systems + components
