Hoffman SYSPEND™ 281-MAX HMI Suspension System
By Patrick Curran | November 17, 2009
Anoka, MN — Hoffman announces the SYSPEND™ 281-MAX HMI Suspension System for supporting and/or repositioning Human-Machine Interface (HMI) enclosures and devices up to a maximum load capacity of 281 lbs. The newest addition to Hoffman’s rugged SYSPEND family of HMI products, the 281-MAX is designed around a modular platform consisting of aluminum tubes and die-cast aluminum components. This flexible system configuration provides an aesthetically pleasing solution for use in a wide range of process control applications where an enclosure needs to be positioned out of the way for cleaning, storage or safety considerations.
The SYSPEND 281-MAX Suspension System includes varying lengths of tubes, elbows, adapters and additional components that can be configured to provide a perfect suspension system for specific applications. The 281-MAX offers ergonomic, fatigue-free operation. Clean lines and smooth transitions between tubes and system components provide attractive aesthetics and easy cleaning. Tubing also provides structural integrity and acts as a conduit for equipment wiring, further enhancing the refined look. Plus, the six-fold positive connection between tubes and components, along with recessed mounting areas, deliver a secure attachment. Tubes attach with set screws that grab into the recesses in the system components for increased safety; no additional safety drilling is required.
Vertical motion tubes provide versatile, height-adjustable solutions for pedestal mounting an HMI Enclosure, and the system design facilitates user-friendly re-adjustment at any time, without disassembling the complete system or calibrating off-site. The 281-MAX features fully gasketed components that maintain the NEMA Type 12 enclosure rating.
Several features of Hoffman’s SYSPEND 281-MAX Suspension System make it particularly easy to use and set it apart from similar systems:
* Supports up to 281 lbs. and allows operators to easily move controls into and out of position
* Includes multiple modular components for simple and ergonomic operation and can be built to fit any application
* Features clean lines and smooth transitions between tubes and system components for attractive aesthetics and easy cleaning
* Delivers structural integrity via tubing that acts as a conduit for equipment wiring
* Provides a unique, height-adjustable pedestal mounting solution
* Features tube set screws coated with Loctite™ to seal threaded holes and provide secure connections; allows for easy adjustment of system alignment
* Allows user-friendly readjustment at any time without disassembling the complete system
* Offers cable access covers available on all components
* Provides heavy-duty bearings in all movable joints for convenient, smooth operation and enhanced durability to withstand stresses of repeated use
* Delivers variable torque adjustment available for all rotating components; general adjustment at the bearing with locking handle adjustment on enclosure couplings
* Presents a wide range of configuration components and accessories
Hoffman
www.hoffmanonline.com
Filed Under: Cabinets • enclosures • control panels, Electronics • electrical, HMIs • operator interfaces • monitors, Safety systems + components
molex-premo-flex
Going small with 3D printing
