Harwin has introduced a horizontal version of its 1.25mm pitch hi-rel Gecko connector, reducing the height above PCBs to just 5.6mm. Available in the standard eight positions – 6, 10, 12, 16, 20, 26, 34 and 50 – the new style also facilitates mother & daughter-board configurations.
G125 series connectors offer high performance in a miniature package. The 1.25mm pin spacing results in a 35% space saving over other high-performance connectors such as Micro-D. Connectors can handle 2A per contact and function within a wide temperature range (-65 to +150 degC) and under extreme vibration (Z axis 100g 6m/s). Other features common to the Gecko connector family include polarization points that prevent mis-mating, easy identification of the No. 1 position for fast visual inspection, and optional latches that allow simple and fast un-mating. Special tooling is available to assist un-mating in confined applications. The horizontal style connectors feature an optional mechanical hold-down latching system for additional connection security.
Harwin
www.harwin.com
The post Horizontal Gecko connectors from Harwin increase design flexibility and reduce PCB stacking height appeared first on Connector Tips.
Filed Under: Connectors (electrical) • crimp technologies, Connector Tips, MOTION CONTROL
