How mussels are leading to more effective adhesives
By Michelle Froese | October 8, 2021
Researchers from McGill University have been investigating how to manufacture a stronger, more reliably adhesive that can withstand moisture and water by taking a close look at mussels — yes, those creatures that abide in and around the water. A type of bivalve mollusk, mussels are similar to clams and oysters, and thrive in saltwater, though also live in the sand and gravel bottoms of streams and rivers.
Scientists have recently developed underwater adhesives and surgical glues inspired by byssal thread chemistry (from mussels). The identification of the mechanisms involved in creating the glue should advance work in this field. Learn more here).
In a paper recently published in Science, a McGill-led international research team reports that, after a decade of work in the area, it has succeeded in uncovering the cellular mechanisms by which mussels fabricate underwater adhesives. Here are their findings…
Blue mussels (Mytilus edulis) spend their days being buffeted by crashing waves. They manage to stay tethered to the rocks or their fellow mussels thanks to a highly effective underwater glue they produce.
Achieving adhesion in the presence of water is challenging, so scientists who are interested in producing effective adhesives for use in wet environments (particularly for surgical or dental treatments) have turned to mussels for inspiration.
“The specific mechanism by which mussels produce their adhesive has been shrouded in mystery until now because everything occurs hidden from view inside the mussel foot,” says Tobias Priemel, the first author on the paper, a PhD student in the Harrington Lab, who has been working on this research for the past seven years, originally as a MSc student in Germany.
He added: “To understand the mechanisms involved we applied advanced spectroscopic and microscopic techniques and developed an experimental approach that combined several advanced and basic methodologies from across biochemistry, chemistry, and materials science.”
Mussels make glue in minutes
By gathering information at a subcellular level, the researchers discovered that within the mussel foot, there are micron-sized channels (ranging in diameter from 1/10 to the full width of a human hair), which funnel the substances that come together to make the glue.
Condensed fluid proteins in tiny sacs (vesicles) are secreted into the channels where they mix with metal ions (iron and vanadium, taken up from seawater). The metal ions, which are also stored in small vesicles, are slowly released in a carefully timed process, eventually curing (or hardening) the fluid protein into a solid glue.
The accumulation and use of vanadium is especially interesting, since only a few other organisms are known to hyperaccumulate vanadium. The researchers believe that it plays an important role in hardening the glue and are continuing to work in this area.
“Mussels can make their underwater adhesive within 2-3 minutes by mixing metal ions with the fluid proteins,” explains Matthew Harrington, an associate professor in McGill’s Chemistry Department and the senior author on the paper. “It’s a matter of bringing together the right ingredients, under the right conditions using the right timing. The more we understand about the process, the better engineers will later be able to adapt these concepts for manufacturing bio-inspired materials.”
To read the full paper in Science, click here.
