How tacho generators help skiers ascend mountain railways
By Mike Santora | August 25, 2020
Baumer-Long Life
Drives are only as good as the current speed feedback, so speed sensors must meet the highest requirements. The Baumer HÜBNER LongLife tacho generators with commuter-embedded silver track are suitable for this demanding task.
Tacho generators in drives of mountain railways and ski lifts are exposed to enormous strain. Nevertheless, they must perform for precise and reliable speed measurement. This is why manufacturers rely on HeavyDuty solutions from Baumer Hübner. What does it take for a tacho generator to withstand the rough conditions on snow-covered mountains?
Every day, and for many years, the cable railway traveling in the Tyrolean Alps to the top of Zugspitze has been carrying hundreds of people to an altitude of 2,964 meters. At a speed of 10 meters per second, the trip takes about seven and a half minutes, powered by two electric motors of 500 kW. In the driver’s cab, control of the current motor status — slow, idle, forward, reverse, accelerate, high-speed, and brake — requires high accuracy and reliability by the speed control system.
However, the components in mountain railways are exposed to harsh conditions: Wind, rain, and snow shape the ambience, temperatures range from double-digit minus degrees in winter to high plus degrees in summer. A perfect application example for the Heavy Duty tacho generators from Baumer Hübner, here analog tacho generator TDP 0.2 LT which is a particularly robust and precise speed sensor variant. What exactly does “HeavyDuty” mean?
HeavyDuty means “heavy-duty.” To Baumer Hübner, however, this is much more than thick-walled housings and corrosion protection¤ HeavyDuty is the encompassing promise of never letting users down thanks to reliable performance for many years. A prerequisite, particularly in mountain railway applications.
Mechanical robustness is key. Tacho generators in mountain railway drives must withstand shocks, vibration, and the other impacts the rotating shaft is exposed to for many years, without losing their functionalities. Product exchange is expensive, not because of tacho pricing, but because of installation in places difficult to access and system downtime during exchange. Robust housings with solid walls are a good start, so TDP 0.2 LT comes in a die-cast aluminum housing and with stainless steel shaft. Also, the interior must be protected against shocks and vibration. TDP 0.2 LT with bearings at both shaft ends is capable of enduring high radial and axial shaft load.
HeavyDuty tacho generators must withstand dust, dirt, and moisture which requires a sufficient level of tightness. For this reason, the HeavyDuty housing is well-sealed, especially at critical, neuralgic points — shaft and electrical connections. In addition, appropriate materials and coatings protect against corrosion by saltwater or chemicals.
Tacho generators do not integrate electronics and therefore are durable against the harmful impacts of electromagnetic fields. Furthermore, shaft currents induced by voltage differences might burn the bearing lubrication which results in bearing destruction. The electrically insulated interior of HeavyDuty tacho generators is therefore well protected against such harmful influences.
Last but not least, precision is another feature of these HeavyDuty components. Tacho generators must deliver reliable signals at all times to ensure precise drive control and regulation. Based on the speed information, the controller can identify any drive speed deviation and will intervene. HeavyDuty tacho generators in heavy vehicles such as mountain railways must be as precise as smaller speed sensors. It is not without reason that TDP 0.2 LT is field-tested and extremely reliable. It delivers a 60V output signal already at 1000 rpm; at the maximum operating speed of 10,000 rpm the controller is even provided with up to 600V.
High-precision tachometer voltage throughout the entire speed range
The conventional combination of copper commutator and graphite brushes in tacho generators has long been outdated. The copper oxide layers on the commutator cause irregular transition resistance and thus high ripple in tachometer voltage, so low speed would not be accurately detected. However, graphite with good sliding properties ensures a long brush service life. The combination of copper commutator and silver graphite brushes is much more appropriate for low-speed detection, since precious metal brushes apply a highly conductive “patina” to the commutator. However, this solution is sensitive to adverse ambient conditions such as oil, grease, or air containing sulfur and salt. Under such conditions no patina would build up and the good transmission properties would be lost over the entire speed range. Additionally, there is increased wear because the metal-containing brushes run directly on the copper layer.
004_Baumer_Kugellager
HeavyDuty tacho generators from Baumer Hübner GmbH excel by robust design with bearings at both shaft ends. Thanks to its resistance to axial and radial loads, this double-sided bearing setup ensures maximum reserve capacities and unmatched service life.
LongLife tachometer technology combines the benefits of the above procedures and eliminates the drawbacks. In a special process, and depending on the tacho variant, Baumer Hübner embeds one or two massive silver tracks into the commutator surface. The track can be very fine thanks to relatively minor tacho currents. TDP 0.2 LT features even two silver tracks. This ensures permanent low contact resistance even under difficult conditions. And it allows for a 60 mV/min-1 voltage constant of TDP 0.2 LT resulting in a wide detectable speed range from ≤ 0.08 to 10,000 min-1, with both mechanically and electrically limited maximum speed. TDP 0.2 LT, therefore, provides a dynamic range of 1: 125,000. The brushes, especially modified by Baumer Hübner, together with the LongLife commutator, provide maintenance-free service life that even will exceed that of the ball bearings.
Ski lifts carrying millions of skiers to mountain peaks every year have likewise tough requirements on drive control. To ensure passenger safety, manufacturers rely on tacho generators that have proven themselves in many applications. They ensure reliable equipment functionality even during severe frost, snowfall, and icy winds. Today, speed-controlled drives are also common in ski lifts for smooth starts and variable travel speed.
The tacho generator is directly connected to the slowly rotating cable wheel via step-up converter and chain wheel drive. This way, dead speed in the motor gearbox is isolated from the control loop and generates sufficient speed signals even under harsh ambient conditions. The GMP 1.0 also has two silver tracks for permanent low contact resistance and thus a widely detectable speed range with good transmission quality of measured values. The robust design and standard temperature compensation make the tacho generator suitable for use in the harsh conditions of snow-covered mountains.
More than half a century of experience in HeavyDuty tacho generators and encoders has evolved Baumer Hübner’s portfolio of reliable, precise and durable product variants from small to large designs. They support all relevant analog and digital interfaces and excel with the capabilities required to withstand even adverse ambient conditions. Application examples like mountain railways and ski lifts clearly prove that for users with high requirements the HeavyDuty Original is the right choice in this encoder class.
Baumer Hübner
baumer.com
Filed Under: Product Design & Development
Tagged With: baumerhübner
2022-347-348_AS_10K3
Corrosion protection for oil and gas equipment from General Magnaplate
Honeywell announces Spring 2022 release of new offerings to Honeywell Forge
unnamed-33
igus introduces new geometries and new materials to its FastLine service
EXAIR’s CE Compliant Chip Vac
