Make sure you’re using the proper combination of components to accurately dispense 2-part materials with Nordson EFD’s new guide, “How to Select the Best Two-Component Dispensing System.”
Useful step-by-step guide helps ID the best cartridge, piston, mixer, and dispense gun or meter mix valve based on several factors critical to optimized dispense performance. Options are based on your fluid material, ratio, fluid viscosity, volume, application, and more.
