Howden American Fan Co., manufacturer of industrial fans and blowers, announced its line of turbo pressure blowers, ideal for higher-pressure systems in combustion air, air pollution control, textile fiber stripping, recycling applications, chemical, pulp and paper, glass, and food processing industry applications. With a wide range of accessories, Howden American Fans customizes the turbo pressure blowers to each individual customer’s system requirements – while maintaining a lead time of less than 10 working days.
Key Features
- Turbo pressure blowers for pressures to 80 inches static pressure water gauge (SPWG), with capacities up to 8000 cubic feet per minute (CFM)
- Fans are available with a wide variety of materials, wheel types, fan arrangements, and sensors
- Application-specific features are added as necessary, for example, stainless steel or other alloy airstream, corrosion-resistant materials and coatings, high-temperature or spark-resistant construction, companion flanges to match ductwork, and pressure gauges
- Constructed from heavy-gage, continuously welded housings, which are reversible and rotatable
- Round inlet and outlets feature flanges drilled to match ANSI 150 # pipe flanges (outlet flange standard)
- Dynamically balanced wheels ensure smooth operation
- Three inlet types are available – stub pipe, flanged, or venturi (standard)
Filed Under: Industrial automation, Blowers
