Huntkey Enterprise Group has delivered numerous industrial power supplies to meet various demands from servers, communication, workstation, storages, networking application or any other automation applications.
Huntkey has released all kinds of form factor power supplies, such as 1U, 2U, 4U, ATX, FLEX, SFX, TFX, and so on. The high-load electrical components adopted by Huntkey industrial PSUs make them work perfectly in an industrial environment. In addition, with its full range of input and output electrical features, Huntkey products also comply with the latest safety and EMC standards, and therefore meet various regulations all over the world. Customers will be impressed by the longtime working and stable performance of Huntkey industrial PSUs.
FLEX:
Model: HK205-93FP/HK250-93FP/HK320-93FP
Rated power: 105W/150W/220W
Dimension: W82*H40*L150mm
Fan: 40mm dual ball bearing
Features:
- Complies with Intel Flex ATX12V specification
- Full range input 90~264V AC, active PFC design
- 40mm dual ball bearing fan with smart control circuit
- Multiple protection: OVP, OCP, OTP, UVP, OPP & SCP
- High efficiency, high reliability, low ripple and low noise
- Multiple safety certification: CCC, CE & CB
- Widely used in set-top boxes, firewalls, routers, NAS, media player, POS, advertising player, conferencing systems and other industrial applications
SFX:
Model: HK300-43FP/HK350-43FP
Rated power: 200W/250W
Dimension: W110*H63.5*L125mm
Fan: 80mm ball bearing<
Features:
- Suitable for Micro ATX form-factor
- 60mm ball bearing fan with smart control circuit
- Widely used in embedded DVR, set-top boxes, banking equipment, AIO, advanced server, NAS, industrial power system and other industrial applications
TFX:
Model: HK350-62GP
Rated power: 250W
Dimension: W85*H70*L175mm
Features:
- Input 115/230V AC, optional passive PFC design
- 80mm ball bearing fan with smart control circuit
- High quality components
- Widely used in embedded DVR, set-top boxes, banking equipment, AIO and other industrial applications
1U:
Model: HK302-11UEP/HK352-11UEP/HK451-11UEP
Rated power: 200W/250W/350W
Dimension: W100*H40*L190mm (W100*H40*L215mm for HK451-11UEP)
Fan: 40mm ball bearing
Features:
- Complies with SSI EPS V2.93 specification
- Suitable for 1U form-factor
- 40mm ball bearing fan with smart control circuit
- High efficiency, high reliability and high quality capacitor
- Low ripple and low noise
- Widely used in network server, IPC and storages
2U:
Model: HK500-12UEP/HK600-12UEP/HK700-12UEP
Rated power: 400W/510W/600W
Dimension: W100*H70*L240mm (W100*H70*L270mm for HK700-12UEP)
Fan: 1*60mm ball bearing/1*60mm+1*50mm ball bearing/2*60 ball bearing
Features:
- Suitable for 2U form-factor
4U/ATX:
Model: HK520-53PP/HK600-53GP/HK701-11PEP
Rated power: 420W/500W/600W
Dimension: W150*H86*L170mm (W150*H86*L180mm for HK701-11PEP)
Fan: 2*80mm ball bearing (1*80mm ball bearing for HK701-11PEP)
Features:
- Suitable for 4U /ATX form-factor
- Full range input, active PFC
- Support SATA and disk array
- Widely used in network server, IPC, VOD and diskless servers
Huntkey
www.huntkeydiy.com
Filed Under: Power Electronic Tips
