A new, miniature Circuit Board Test Point launched by Keystone Electronics features the ability to be mounted on a PCB via Surface Mounting methods with locating pin.
This latest addition to the extensive Keystone line of circuitry test points is designed with a unique hybrid mounting style which maximizes the efficiency of SMT contacts with the strength and durability of thru-hole solder connections to a circuit board. This new Test Point has a locating pin design to provide positive location of the device during the assembly process.
Catalog No. 5027 features a symmetrical flat-wire design making it a superior anchoring point for probes, j-hooks and other circuit testing devices while minimizing shifting and pull off damage which is common on standard SMT terminals.
Manufactured from Phosphor Bronze with Silver Plating gives this test point the versatility for use in both lead-free and traditional leaded processing. Packaged 800 pieces on tape and reel, per ANSI/EIA-481 standard, for vacuum pick and place assembly systems. As with all Keystone products, delivery is prompt via its global distribution network.
A major manufacturer of interconnect components and electronic hardware, Keystone’s capabilities include stamping, machining and assembly service. Application engineering assistance for product modifications and special designs are also available. ISO-9001 certified and RoHS compliant, company headquarters are in the USA with offices in Canada, Europe, Australia and Asia.
Keyelco
www.keyelco.com
The post Hybrid-mount PCB test point couples surface mounting with locating pin appeared first on Analog IC Tips.
Filed Under: MOTION CONTROL, Analog IC Tips
