HydraForce Hydraulic Relief Valves
By Design World Staff | November 5, 2008
New RV08-29x direct-acting, poppet-type, hydraulic relief valves are intended for controlling pressure in low-flow pilot circuits. They are rated up to 3500 psi/241 bar with an adjustable pressure range from 1000 to 3500 psi (69 to 241 bar), and a flow range up to 0.5 gpm/1.9 lpm. The RV08-29x valves are designed to enhance the stability of pilot function pressure control.
RV08-29x valves feature a very low internal-leakage rate of 0.18 cu. in/min (3 ml/min) to 80% of nominal setting, which ensures accurate system regulation. Adjustment options are either a 1/4-inch hex allen head adjustment, or a factory
preset hidden adjustment. Seals are standard Buna N, or fluorocarbon for higher temperature applications. HydraForce is committed to continuing innovation in the
design, manufacture, and application of hydraulic and electro-hydraulic control components and systems for the material handling and heavy-duty mobile equipment OEM
industries.
www.hydraforce.com
Filed Under: Valves, FLUID POWER
