Edited by: Michael Jermann/ Assistant Editor
A coffee equipment manufacturer had been designing coffee roasters for decades using a chain and sprocket system. Due to the cumbersome alignment and installation, the manufacturer sought an alternative approach to reduce manufacturing time and lower total installed cost of new equipment. Bison Gear and Engineering met with the manufacturer to discuss these issues, sharing the benefits of the PowerSTAR hypoid gearmotor and suggested it would be an excellent solution for their new system.
The chain/sprocket configuration was initially selected for a number of reasons. First, the manufacturer needed the ability to adjust for different output speeds to match different types of coffee beans. The chain/sprocket assembly allowed for speed control by changing sprocket sizes. Second, temperature created by the rotating roasting drum originally prohibited a direct drive system, since it would cause failure after a short period of time. Finally, the cost of an alternate system in comparison with chain and sprockets discouraged the manufacturer from pursuing it.
The original chain/sprocket design of the coffee roaster was modified to include a remotely mounted gearmotor but keep the same overall function (interchanging sprocket sizes to control the speed). The gearmotor required additional mounting, framing and alignment. This increased install time and cost, resulting in the manufacturer looking for ways to further improve the coffee roaster.
After meeting with their design team to better understand the criteria and performance issues, Bison engineers recommended the PowerSTAR right angle hypoid gearmotor as a direct drive system – replacing the current design. The gearmotor features imperial and metric mounting configurations for easier installation. Using the PowerSTAR in a direct drive configuration for the rotating drum would save the manufacturer installation and alignment costs, as well as improve energy efficiency. While the manufacturer was impressed, they still considered heat created by the drum to be a gating factor when implementing a direct drive system. To confirm the unit would perform, Bison agreed to provide sample PowerSTAR units to test performance within the application.
The initial benefits of PowerSTAR were realized early on in the test. The transition between the initial designs to a direct drive system resulted in dramatically reduced install components. The eliminated components also yielded a reduced installation time since there were fewer sub-assemblies to mount and align. The PowerSTAR also proved the robustness of its design throughout the testing phase, and was specified into the new coffee roaster design.
www.bisongear.com
Filed Under: TECHNOLOGIES + PRODUCTS, Design World articles, Gears • gearheads • speed reducers
