Replacing a standard washer with a HYTORC Washer makes a job safer, faster and more accurate while increasing the lifespan of your tools. This upgrade can be used on nearly every bolting application without changing your existing bolts and nuts. The design provides advantages in safety, speed, and accuracy. For instance:
- Increase job safety – The elimination of external moving parts and the intuitive design of the HYTORC Washer system make it the safest bolting method in the industry.
- Increase joint integrity – The HYTORC Washer ensures even and accurate bolt load to eliminate joint failure and unintentional nut loosening
- Increase tool longevity – Other bolting systems put the reaction arm and square drive on opposite sides of the tool causing high stress in the body of the tool, which can lead to failure over time. The HYTORC Washer puts the action and reaction on the square drive axis to eliminate the majority of internal stress, and increase the lifetime of your tools.
Hytorc
www.hytorc.com
Filed Under: Green engineering • renewable energy • sustainability
