HYTORC’s 36-V battery powered torque guns combined with the HYTORC Washer are the ultimate solution, says the company, for portability and convenience in industrial bolting. The tool is safer, faster and more accurate than all comparable systems.
High speed rundown, final torque and angle capabilities
The Lithium Series dual speed torque gun provides the speed and convenience of a pneumatic torque gun without the noise, vibration and load variation.
In speed mode, high RPMs provide quick rundown or removal.
In power mode, high power provides accurate final torque or for tough break-outs.
Bolt load accuracy to ±5%
The Lithium Gun is a precision torque and tension-compatible machine that users can set and get required loads. The gun Gun uses precision gearing to produce constant, calibrated power assuring that you will achieve bolt load within your window of accuracy every time.
Lightweight, durable & powerful
The tool has the highest power-to-weight ratio of any battery powered torque gun. High quality components ensure superior performance and durability. An aluminum frame makes it lightweight yet resistant to damage.
User interface
The user-friendly graphical interface gives you three options for bolting preference and allows for saving of custom settings. On-site safety and operational training is provided free of charge to all customers to ensure safe and efficient operation.
Filed Under: Green engineering • renewable energy • sustainability
