iCAP series ultracapacitor is now more powerful and more efficient
By Natasha Townsend | June 6, 2013
The 1200 Farad (F) cell high performance ultracapacitors is a high-powered energy solution that optimizes the performance of lead acid, AGM and Lithium Ion batteries in cars, tractors and motorbikes, enabling improved start/stop technology performance and serving as a reliable and cost-effective feature of hybrid engine vehicles. With the widespread availability of iCAP ultracapacitor cells, manufacturers gain unmatched durability and adaptability to support a wide array of applications.
The 1200 F cell plays a key role in several applications within the automotive industry, including: engine starting and cranking; transportation drive systems; and regenerative energy capture. Engineers will appreciate its structural features, which were designed for easy and error-free assembly. The cell was designed with high-shock and vibration applications in mind and has a wide variety of technical features, including:
  • 2.7 V working voltage
  • 84% higher power density than comparable products
  • Lowest cell ESR on market: 25 mOhms ac and 30 mOhms dc
  • Highest power density: 25 kW/kg or 32 kW/L
  • Long life cycle: 1 million + cycles
Ioxus has launched three new modules, the iMOD 80V/12F, 16V/500F and 48V/165F.
Ioxus
Power Supply Tips
Filed Under: Power Electronic Tips, Power supplies
Tagged With: ioxus
schurter
Compact power entry module has side flange mounting option
ABSOPULSE
Three-phase power supplies with active PFC handle 5-kW industrial applications
Sager Electronics to carry SL Power’s 300-W single-output power supplies
wuerth catalog
Catalog covers certified components for automotive electronics
