icotek expands its range of adapter grommets
By Michelle Froese | October 7, 2020
Several ictoek grommets are ideal for creating an interface for signal, data, power, and hybrid connectors by simply screwing them into the AT-M thread.
icotek is expanding its range of adapter grommets for its IMAS-CONNECT adapter system to include the AT-PP and AT-K-M. IMAS-CONNECT is a modularly designed grommet (ring) system for mounting circular connectors, jacks, connectors, pressure-compensation elements, and more.
The new AT-PP adapter grommet is based on a KT large cable grommet. A polyamide body is integrated in this elastomer grommet. Thanks to the screw-on housing, the “compact” PushPull module systems can be routed into the grommet.
By using the AT-PP adapter grommet, pre-assembled cables and Push Pull termination points can be routed through the same knock-out. This reduces the need for multiple knock-outs, reducing labor, time, costs, as well as space on the side of a machine. The AT-PP has protection class IP65.
The AT-K-M adapter grommet is based on a KT small cable grommet. A nickel-plated brass body is integrated in this grommet. The AT-K-M is available with internal threads M5 x 0.5, M8 x 1.0, M12 x 1.0, M12 x 1.5, M14 x 1.0 and M16 x 1.5.
By using the AT-K-M adapter grommet (e.g. pneumatic bulkhead plug connections, M 12×1.0, M 14x 1.0, 1/8″, and 1/4″), numerous round plug connectors and pressure-compensation elements are integrated directly into the cable entry.
The adapter grommet is also compatible with all icotek cable-entry systems where our traditional KT grommets can be used. The AT-K-M has a protection class up to IP66 depending on the type of cable entry used. All previous IMAS-CONNECT adapter grommets fit into the KEL systems as well as the QUICK systems from icotek.
Tagged With: icotek
