IDEM non-contact RFID coded safety switches from AutomationDirect are designed to provide interlock protection on hinged, sliding, or removable guard doors. These switches are particularly advantageous when poor guard alignment exists, when high-level anti-tamper is required, where high-hygiene requirements exist, (food industry hose down applications) or where long mechanical life is required. When used in combination with a dual-channel safety relay or control device, IDEM non-contact safety switches can provide protection up to Category 4 and PLe to ISO13849-1.
New IDEM KLP-Z, KLM-Z, and KL3-Z series tongue interlock safety switches with guard locking and RFID coding, fit into the leading edge of machine guard doors to provide robust guard locking while also providing a double tamper-resistant interlock mechanism. Providing position detection for moving guards, these switches remain locked until the solenoid voltage is applied to the switch. The switches can also be used in conjunction with delay timers to provide the solenoid energize signal only after a pre-determined amount of time has passed.
Also new, IDEM LMF series stainless steel RFID coded safety switches provide a wide 10mm sensing distance; and new M18 cylindrical barrel BPF/BMF series safety switches offer high tolerance for misalignment after sensing and are suitable for all industry applications.
AutomationDirect
www.automationdirect.com/safety-switches
Filed Under: Sensor Tips
