ifm Metal Face Sensors
By Design World Staff | May 12, 2008
ifm's metal face sensors are designed and tested to provide reliable position detection in the toughest welding and metal stamping applications.
• Stainless steel sensor face and housing withstand damage from physical impact in the part loading process in manufacturing cells.
• High temperature weld slag resistant coating prevents weld slag from adhering to the sensor, eliminating abrasive cleaning techquies.
• Extended sensing range increases the distance between the sensor and the target.
• Weld field immune electronics
ifm metal face sensors are specifically designed and tested for welding and stamping applications. Stainless steel construction and a high temperature weld slag resistant coating extend the sensor's life-in-application by a factor of 15 compared to teflon or plastic face sensors.
www.ifmefector.com
Filed Under: SENSORS, ELECTRONICS • ELECTRICAL
