The new iglidur TX2 plain bushings were developed for use in particularly highly loaded bearing locations. Due to its incorporated solid lubricants, the high-strength, wound construction ensures for a low-friction and maintenance-free operation – entirely without external lubrication.
Tech up
Particularly low wear in the heavy-duty area
Up to 3.5 times more wear-resistant than iglidur TX1
Cost down
Maintenance-free properties reduce costs for lubrication and maintenance
Cost-effective even in high dimensions and low volumes
Proof
Tested in our own test rigs inside and outside.
Test parameters: 50°pivoting movement, shaft Cf53 hard-chrome, p = 100N/mm², v = 0.01m/s
Sustainability
Environmentally friendly as no additional lubricants needed
Good coefficient of wear and therefore a long service life
igus supports the circular economy of plastics and is investing in chemical recycling. Learn more about this topic.
igus
www.igus.eu
Filed Under: Bearing Tips
