    • Subscribe!
IKO cam follower prevents metal-to-metal wear when handling high loads
By Mike Santora | October 1, 2020
IKO_CR...VBSIKO International has introduced a cam follower designed to handle heavy loads and their associated thrust loads. The CR…VBS Series features a proprietary sealing technology called ThrustDisk along with a radial gap to alleviate impact loading.
In heavy-duty cam-driven machines, improper mounting often causes misalignment that produces thrust forces and metal contact between the bearing’s outer ring and side plate. Heavy loading also creates deflections and uneven loading at the stud. Heat resulting from metal-to-metal contact can further reduce the cam follower’s life.
The CR…VBS’ ThrustDisk seal is made from a synthetic resin with a very low wear rate. Along with its built-in thrust washer, ThrustDisk goes into sliding contact areas of the unit’s outer ring, stud head, and slide plate to handle axial loads, preventing wear and friction caused by mounting errors. It also resists heat and contamination to improve the bearing’s lifetime. Other features include a low coefficient of friction, good rotational performance, and a hex head stud for easy mounting.
CR…VBS cam followers with ThrustDisk technology are part of IKO’s Inch series family, which are designed for a broad range of applications such as machine tools, industrial robots, packaging and handling and food processing equipment.
IKO
www.ikont.com
Filed Under: Bearing Tips
Tagged With: iko
U.S flagged Great Lakes bulker now operational with Thordon Bearings
Insulate CERAMICSPEED radial bearings
Bearing solutions for higher power density, and lower carbon footprint
New king pin and thrust bearings save costs for forklift company
    • Subscribe!
