IKO International is building on its standard MX series of linear roller bearings to include special features for environments that are sensitive to metal chips, dust, and other contaminants.
Dust protection
A dust protective C-Wiper can be mounted to the outside of the end seal, ensuring operation in environments where metal chips are spattering. After 1,000 km of operation, the C-Wiper prevented foreign substances from entering the slide unit with no damage to the end seal.
Maintenance-free
The MX specification integrates IKO’s proprietary C-Lube lubrication system. As the cylindrical rollers circulate, lubricant is distributed to the loading area through the rollers along the track rail. Lubrication is properly maintained in the loading area for over 12,500 miles (20,117 km), reducing valuable time spent lubricating hard to reach parts.
High load capacity
The MX models utilize rows of cylindrical rollers to provide a greater contact area than slides that use steel balls. They also maintain high rigidity in every direction. As a result, bearings deliver high load capacities – up to 674 kN for dynamic loads and 1,300 kN for static loads.
Mounting dimensions are compatible with MH and LWH ball type series. If you want to transition from a ball type to a roller type, your mounting dimensions do not need to change.
For more information, visit www.ikont.com
Filed Under: Linear Motion Tips, Bearings, Motion control • motor controls
