IKO’s new LWLF2 miniature linear guides simplify mounting in tight spaces
By Heather Hall | March 24, 2022
Expanding its LWL family of miniature guides, IKO introduces its LWLF2 linear motion rolling guide, which addresses the demand for device miniaturization with a compact, lightweight design that makes mounting easy in tight spaces.
The new LWLF2 features the same ultra-small 2.5-mm height dimension as its predecessor, the LWL1. It is also designed with tapped rails for bottom mounting and stability. As part of IKO’s LWL family of miniature rolling motion guides, the LWLF2 guide is structured with two rows of balls that make contact with the raceway at four points to provide high stability and accuracy — even in applications with varying load direction or complexity.
Additional features of the LWLF2 include:
-Compact size. In addition to its 2.5 mm sectional height, the LWLF2 has a track rail width of 2 mm and slide unit width of 5 mm.
-Corrosion resistance. Stainless steel construction is standard, making the new guides desirable in wet environments and applications where rust prevention oil cannot be used, such as in a cleanroom environment.
-Light weight. The LWLF2’s rail weighs 2 g per 100 mm of length, and the slide unit weighs 0.21 g.
IKO’s LWL family of miniature linear motion rolling guides is appropriate for robotics and grippers, semiconductor fabrication, life science and aerospace applications.
You may also like:
  • What are piezo flexure stages and how do they work?
  • Linear bearing basics: Surface roughness, texture, and finish
  • Teflon composite bearings now available as twin pillow block linear…
  • Five ways to drive ROI from personnel and cobot investments
  • Linear Guides That Improve High-Precision Applications
  • Motion system design: How to manage inertia mismatch
Filed Under: Linear motion • slides
Tagged With: iko, ikotek, ikointernational
LM76-SPEED DEMON EL300 4x5x300
LM76 SPEED DEMON EL300 for high speed, low friction, smooth linear motion
Stainless steel linear guide rail systems
LWLF2_FAM
IKO’s New LWLF2 Miniature Linear Guides
igus introduces self-lubricating toothed belt axis designed for clean use in food technology
