F99 Inclination Sensors are available with CANopen interface. You can configure and monitor the incline or tilt angle of machine elements or equipment platforms in single or dual axis applications, from 0° to 360° with accuracy of ± 0.5°, through the CANopen interface.
The sensors feature metal mounting brackets, an outdoor IP68/69k rating, high shock resistance to 100 g and models with either 4-20 mA or 0 to 5 Vdc analog outputs that can represent the user-configured angle range. They feature a power supply range of 10 Vdc to 30 Vdc, two adjustable switching outputs and operate in temperatures from -40° C to 85° C.
Pepperl+Fuchs
www.pepperl-fuchs.com
Filed Under: Electronics • electrical, Networks • connectivity • fieldbuses, Sensors (position + other), Test + measurement • test equipment
