    • Subscribe!
Inductive couplers for discrete sensors transmit power, signals across air gap
By Mary Gannon | November 11, 2019
Balluff’s inductive couplers connect up to eight discrete sensors across a small air gap, eliminating hardware failures that can occur when slip rings, connectors, or other electromechanical connections wear out.
Balluff inductive couplersThe M18 cylindrical version can connect to up to 4 discrete PNP sensors with 100 mA of output current, and the Q40 cuboid version can connect to up to 8 with 500 mA of output current. Both versions have an IP67 rating. Balluff’s passive junction boxes with M8 or M12 connectors allow you to quickly connect the remote coupler to the sensors.
Multiple remote couplers can be used with a single base coupler. This makes these couplers a smart retrofit for applications like die molds, where in-die sensor cables must be disconnected and reconnected frequently, eventually causing them to fail. With inductive couplers, you mount the remote coupler at the same position on each die or mold, then set the needed die or mold in place. Once the base and remote are in close proximity, LEDs on the base and remote switch on to indicate that a connection is active.
The key features of the inductive couplers for discrete sensors include
  • Two form factors
  • 18 mm cylindrical (M18) unit for up to four sensors
  • 40 mm cuboid (Q40) unit for up to eight sensors
  • IP67 protection for harsh environments
  • Internal temperature monitoring
  • LEDs visualize operating status on base and remote
Balluff
www.balluff.com
Filed Under: Sensor Tips
Tagged With: balluff
LPPS-36B Series Linear Potentiometer Position Sensor with Rod Ends
Hybrid sensors for connected vehicles
How are wearable systems improving?
Faster than any other IDS industrial camera: uEye Warp10 with 10GigE
    • Subscribe!
