AutomationDirect has extended its offering of industrial sensors to include the PEW series of stainless steel DC proximity sensors. The shielded 8mm sensors are flush-mountable and feature a 2mm sensing range. Available with either M8 or M12 quick disconnects, they are equipped with LED status indicators visible at wide angles, and have PNP outputs. PEW series inductive proximity sensors are priced at $45.
Also added are the LF40 series rectangular inductive DC proximity sensors. Two shielded and two unshielded models are available with 20mm or 35mm sensing ranges. The rectangular plastic PNP sensors provide either normally-open or normally-open/normally-closed complementary outputs. LF40 series sensor prices start at $39.
AutomationDirect
www.automationdirect.com
Filed Under: Factory automation, Sensors (proximity), Test + measurement • test equipment
