Now popular Norgren Automation Solution thread detection sensors are available 24/7 at the Norgren Express webstore. Norgren nut and thread detectors use inductive proximity detection technology to sense the presence of a welded nut through a blind hole in sheet metal parts. This unique sensing probe develops a radial detection field to verify that the nut totally surrounds the probe and is properly positioned. The system can often be tuned to verify thread presence and quality.
The all stainless steel probe resists weld splatter, and the sensing circuitry will not be damaged by the weld field environment. This allows the sensor to be used very close to the welding operation for detection of an incorrectly built part early in the assembly process.
These sensors are available at Norgren Express, Norgren’s fast-track, multi-channel bridge to thousands of quality products and immediate technical engineering advice for pneumatic motion and fluid control. Norgren Express minimizes machine downtime, with most components in stock for rapid dispatch.
Norgren
www.norgrenexpress.com
Filed Under: Pneumatic equipment + components
