Industrial 8-port gigabit managed switches
By Frank Tobe | March 24, 2016
AntairaThis industrial gigabit managed Ethernet switch line (LMX-0804G-SFP series) operates in applications in harsh or outdoor environments, such as power and utility, solar grids, windmills, mining infrastructures, and factory and process control automation.
This 8-port switch has a 12-to-48-Vdc power input range, four 10/100/1000Tx RJ45 ports, and four 100/1000 dual rate SFP slots for flexible fiber connection options. Four fiber ports let users implement these switches in a fiber optic ring.
With a 16-Gb backplane speed, the switches support Jumbo Frame and wide bandwidth for huge Ethernet data packet transmission for edge level connectivity solutions. The product series provides high EFT, surge (2,000 Vdc) and ESD (6,000 Vdc) protection. It is also built with a dual power input design with reverse polarity protection, and has a built-in relay warning function to alert maintainers when power failures occur. This makes it suitable for applications demanding a high reliability and distance extension.
This product series is pre-loaded with “Layer 2” network management software that supports an ease-of-use Web Console or Telnet through the serial console by CLI configuration.
Each series is built to withstand industrial networking hazards like shock, drop, vibration, electromagnetic interference (EMI) and extreme temperatures.
There are two operating temperature version models for either standard temperature (-10 ~ 70° C) or extended temperature (-40 ~ 75° C). The models are
54 × 99 × 142 mm and weigh 2.4 lb.
Antaira Technologies
www.antaira.com
Filed Under: TECHNOLOGIES + PRODUCTS, Switches
Tagged With: antaira
Screenshot 2022-05-10 at 12.00.35 PM
FAULHABER: Everything under control
Rockwell Automation offers new online capabilities with industrial automation software
NYE adds Vishay Miniature Position Sensor to product lineup
