    • On the Floor
Industrial Compact Ball Valves
By Design World Staff | October 14, 2008
Hayward Flow Control Systems has announced availability of a new line of compact ball valves for a wide range of heavy duty chemical, water, and waste water applications.
QVC and QTA Series Industrial Compact Ball Valves feature a rugged, all-plastic design usually found on higher cost ball valves, socket or threaded pipe connectors, Santoprene (TPV) seats, full porting, and a 150 PSI pressure rating. QVC Series valves available in ‚½” – 4″ sizes in gray or white PVC, QTA Series valves are available in ‚½” – 2″ sizes in gray or white PVC, and include socket and threaded True Union end connections.
Perfect for OEM and other applications that require a reliable ball valve at an economical price, the valves provide easy quarter-turn operation and are designed to fit into spaces too small for other valves.
www.haywardflowcontrol.com
Filed Under: Hydraulic equipment + components, Valves, FLUID POWER
  • Industrial automation accelerates with increased capital spending
    • On the Floor
