Wabash Transformer has introduced a configuration of Industrial Control Transformers – Series EJ. Power range from 150VA to 1KVA. 208/230/460VAC input with 24/115VAC output. Various fusing options, e.g. CC, slo-blo midget, for your application. Compact design of transformer meets various international safety agency approvals – UL, CSA, CE. Some of the main features are:
Applications
The international series CT transformers are especially suited for high inrush current and output voltage stability. This is typically the case when electromagnetic devices such as relays, motors, solenoids, contactors, bells, signals and alarm systems.
•Control Panels.
•Factory Automation.
•Building Automation.
•Process Control.
•Material Handling.
•Vending Machines.
•Packaging Equipment.
•Amusement Park Equipment.
•Semiconductor Manufacturing Equipment.
•Instrumentation equipment.
•High efficiency applications.
•Conveyor Systems.
•Machine Tool Equipment.
•Pump Systems.
•HVAC Industry, residential and commercial.
•Motors.
Product Features
•Primary voltage 208/230/460VAC
•Secondary voltage 24/115VAC
•25-5000 VA rating available, 50/60 Hz
•600V class, machine tool rated industrial control transformers
•IEC “Touch proof” terminals
•Finger safe fuse terminal, no pull kits or covers needed
•Slotted mounting holes for quick and easy mounting
•Copper coils for excellent thermal characteristics
•High quality steel for low excitation current
•Impregnation in high grade class varnish assures environmental integrity
•Primary and secondary wound side by side separated by bobbin flange for high isolation up to 2500 Vrms Hipot
•Insulation systems available: 105ºC, 130ºC or 180ºC insulation system. Additional insulation systems available upon request.
•Temperature range: -20°C (-4°F) to 40°C (104°F)
•Meets or Exceeds NEMA, ANSI, NMBTA and NFPA (JIC)
•Rugged construction for hostile industrial environments.
•UL, CSA approved, CE marked and RoHS compliant (UL file # E248236).
•10 year warranty
Benefits of Using Wabash Transformer
•Highly experienced staff of engineers (over 180 yrs of cumulative design and engineering experience).
•Standard (off-the-shelf) and custom products.
•Short lead times on production quantities (stock to two weeks)
•Rapid prototyping.
•Cost competitive quotes.
•Global supply chain provides risk-free and reliable product(s) design and delivery.
Wabash Transformer has been producing quality custom and pre-designed transformers for over 30 years. Our Quality Policy is simple, and effective:
A) Compliance to Requirements.
B) Continual Improvement.
C) Personal Pride in our Work.
Feel free to take advantage of our standard off-the-shelf models or let us customize a transformer to your particular needs. Either way, you’ve come to the right place.
