Ensign Corporation is proud to introduce its configuration of Industrial Control Transformers – Series JE. Power range from 25VA to 5KVA. 220/480VAC input with 25/120VAC output. Various fusing options, e.g. CC, slo-blo midget, for your application. Compact design of transformer meets various international safety agency approvals – UL, CSA, CE. Some of the main features are:
Applications:
The international series CT transformers are especially suited for high inrush current and output voltage stability. This is typically the case when electromagnetic devices such as relays, motors, solenoids, contactors, bells, signals and alarm systems.
•Control Panels.
•Factory Automation.
•Building Automation.
•Process Control.
•Material Handling.
•Vending Machines.
•Packaging Equipment.
•Amusement Park Equipment.
•Semiconductor Manufacturing Equipment.
•Instrumentation equipment.
•High efficiency applications.
•Conveyor Systems.
•Machine Tool Equipment.
•Pump Systems.
•HVAC Industry, residential and commercial.
•Motors.
Product Features:
•Primary voltage 220/480VAC
•Secondary voltage 25/120VAC
•25-5000 VA rating available, 50/60 Hz
•600V class, machine tool rated industrial control transformers
•IEC “Touch proof” terminals
•Finger safe fuse terminal, no pull kits or covers needed
•Slotted mounting holes for quick and easy mounting
•Copper coils for excellent thermal characteristics
•High quality steel for low excitation current
•Impregnation in high grade class varnish assures environmental integrity
•Primary and secondary wound side by side separated by bobbin flange for high isolation up to 2500 Vrms Hipot
•Insulation systems available: 105º C, 130ºC or 180ºC insulation system. Additional insulation systems available upon request.
•Temperature range: -20°C (-4°F) to 40°C (104°F)
•Meets or Exceeds NEMA, ANSI, NMBTA and NFPA (JIC)
•Rugged construction for hostile industrial environments.
•UL, CSA approved, CE marked and RoHS compliant (UL file # E248236).
•10 year warranty
Options Available:
•Primary and secondary fuse blocks (for CC fuses, sold separately).
•Primary and secondary fuse holders (for slo-blo midget fuses).
•Fuse block covers (clear).
•Fuse block covers (with indicator for easy fuse status).
Benefits of Using Ensign:
•Highly experienced staff of engineers (over 180 yrs of cumulative design and engineering experience).
•Standard (off-the-shelf) and custom products.
•Short lead times on production quantities (stock to two weeks)
•Rapid prototyping.
•Cost competitive quotes.
•Global supply chain provides risk-free and reliable product(s) design and delivery.
