Industrial Ethernet CAT 7 and CAT 7A
By Frank Tobe | September 16, 2015
Cable requirements for industrial applications can be extremely demanding. They must be able to perform in tough environmental conditions such as higher temperatures, oil and solvents, aggressive chemicals and/or humidity as well as against strong mechanical stress such as flexing in cable chains or twisting in robot applications.
SAB
Ethernet cables rated for category 5 and 6 from SAB have proven to have excellent performance in such applications. However, the market continues to work on current and future designs demands, especially in automation processes with a permanently increasing data volume and transmission velocity. After considerable design efforts and intensive testing, SAB offers our newest generation of Industrial Ethernet cables, CAT 7 and CAT 7 A Ethernet cables for industrial applications extending the frequency range to 1000 Mhz.
The application possibilities range from a simple flexible application for use in cable tracks and robot applications. The production possibilities cover standard dimensions as well as hybrid cables integrating CAT 7 with other elements per our customer´s request to create composite designs.
SAB North America
www.sabcable.com
The post Industrial Ethernet CAT 7 and CAT 7A appeared first on Wire and Cable Tips.
Tagged With: sabna
Cable assemblies now available in M12 connector types
How can EMI be eliminated from an industrial cable system?
igus creates world’s first e-chain made entirely of recycled material
MMCX Micro-coax cable assemblies increase flexibility and design options
