RICHMOND, VA — Weidmuller announces the introduction of a completely new networking and panel organization device— the NetBloc. The NetBloc line is comprised of eleven different networking terminal units that provide network connection and network cable management on 35mm DIN-rails. This new line provides engineers with a method of organizing, managing, and labeling networking connections in much the same way they currently manage power and signal connections with terminal blocks.
“These new NetBlocs are essentially the terminal block for networking connections”, says Bruce Hofmann, Director of Marketing at Weidmuller, “Now all of the marking and organizational benefits of terminal blocks are available to network terminations.”
There are four unique RJ45 versions including standard RJ45 to RJ45 couplers, RJ45 A-coded, RJ45 B-coded, and RJ45 PROFINET, each rated for cabling and performance to Cat6A. The six fiber optic versions include SC single mode, SC multimode, ST single mode, ST multimode, LC Duplex single mode, and LC Duplex multimode. In addition to these ten RJ45 and Fiber Optic models, there is also a very useful USB-to-USB version for connecting laptop computers or other USB enabled devices.
One of the most unique features of each NetBloc is the functional earth grounding option that can be switched on or off during operation. This provides the built-in option to ground a shielded network connection to the DIN-rail to reduce noise or potential ground loops.
“The NetBloc line of connection technology is the closest thing to an Industrial Ethernet insurance policy that you can get. Why risk running a contaminated wire into your Ethernet switch and damaging a port, or even the entire switch? With NetBloc, the risk of damaging a RJ45 or Fiber Optic port on an Ethernet switch is virtually eliminated. There should be no need for anyone in the field to connect or disconnect the cabling directly from the switch,” said Tobin Robertson, Weidmuller Product Manager.
Filed Under: Ethernet — cables • hubs • switches, CONNECTIVITY • fieldbuses • networks • gateways, Connectors (electrical) • crimp technologies, Industrial computers, Terminal blocks
