    • On the Floor
  • Advertisers
    • PR Submissions
    • Eblast Submissions
Industrial Ethernet Switches from WAGO
By Design World Staff | July 11, 2008
GERMANTOWN, WI ‚– WAGO Corporation‚’s new 852 Series of Ethernet switches provides a wide range of scalable solutions for network infrastructures. The 852 Series ranges from simple Ethernet switches to configurable, multifunction Ethernet communication switches. Features such as a rugged housing give all 852 Series switches an operating temperature of 0‚°C to 60‚°C, vibration resistance (acc. to IEC 60068-2-6) and shock resistance (acc. to IEC 60068-2-27), ensuring the switches can withstand rigorous industrial environments.
852-104 Leads Comprehensively Equipped 852 Series Variants:
‚• 852-101 5-Port 100BASE-TX Industrial Switch
‚• 852-102 8-Port 100BASE-TX Industrial Switch
‚• 852-103 8-Port 100BASE-TX + 2-Slot 100BASE-FX Industrial Switch including two additional SFP module ports (small form-factor pluggable for connecting fiber optic cables)
‚• 852-104 7-Port 100BASE-TX + 2-Slot 100BASE-FX Industrial Managed Switch
The 852-101, -102 and -103 switches are equipped with: a DIP switch for enabling alarm functions; compliance with IEEE 802.3 and 802.3u standards; non-blocking, store-and-forward switching; auto-negotiation on all 10/100BaseTX ports and auto-MDI/MDIX (crossover) on all 10/100BaseTX ports. Operational status LEDs are also included.
The top-tier 852-104 switch builds on these features by adding: Web-based/SNMP management; full compliance with IEEE 802.3x, 802.1d, 802.1q, and 802.1p standards; Xpress Ring; VLAN (802.1q) VID; IGMP snooping for multicast filtering; port configuration, status and statistics; port trunking and SNMP v1/v2 with RMON.
Extensive Ethernet Networking Options:
The 852 Series Ethernet Switches are compatible with other WAGO Ethernet solutions such as the 750-975 RJ-45 Ethernet Connector and the 289 Series of DIN-rail mountable Interface Modules. The versatile RJ-45 connector provides gas-tight, pull-out and vibration-resistant connections for industrial, office and building wiring. The 289 Series of Ethernet Interface modules feature variable shield screen-style connections for additional networking convenience.
www.wago.us
Filed Under: Ethernet — cables • hubs • switches, ELECTRONICS • ELECTRICAL
  • Siemens aims for 80 percent automation in German plant
  • Humanoids building humanoids, and new robots for agriculture equipment in Kansas
  • Amazon takes on another industry: robotics
    • On the Floor
  • Advertisers
    • PR Submissions
