Industrial Ethernet Switches with Alarm Output
By Patrick Curran | July 16, 2009
GERMANTOWN, WI
— WAGO Corporation’s 852 Series Ethernet switches offer an alarm contact, enabled via dip switch, to signal an error condition on the switch. This feature is standard on both managed and unmanaged switches (non-ECO versions).
The power input connector on the switch has two dedicated alarm circuit connections that can be wired to any warning device, such as a PLC or pilot light. Error conditions that can be monitored include port link failure (cable disconnect, network disruption, etc.), power supply disruption/disconnect, or power supply voltage out of specified range (9…48V).
WAGO
www.wago.us
Filed Under: Ethernet — cables • hubs • switches, Networks • connectivity • fieldbuses
Ethernet/IP Network specification complete for Ethernet-Apl physical layer for process automation
Avnu Alliance launches global TSN Certification program
Hardened multi-speed mega PoE injector for diverse infrastructure applications
EKI-7000 Series Firmware Revision makes network management more secure
