    • On the Floor
  • Advertisers
    • PR Submissions
    • Eblast Submissions
Industrial Hub
By Design World Staff | August 1, 2007
The AC808 Ethernet hub is a standalone device that can be used as a Level 2 hub in standard Ethernet or real-time industrial Ethernet Powerlink networks. It is suitable for both 100 MBit/s (Fast Ethernet) and 10 MBit/s networks. The hub automatically recognizes the correct transfer speed and configures the respective channels accordingly.
The Ethernet connections are made using RJ45 connectors. Pin assignments can be crossed for the first channel using a switch, enabling the same type of cable for a connection between hubs (hub-hub) and between a hub and a network station. The hub can be installed horizontally or vertically on the mounting rail. It also has fastening possibilities on the sides for direct mounting.
B&R Industrial Automation Corp.
www.br-automation.com
:: Design World ::
Filed Under: Factory automation, Ethernet — cables • hubs • switches
  • Big growth in U.S. industrial automation
  • Siemens aims for 80 percent automation in German plant
  • Humanoids building humanoids, and new robots for agriculture equipment in Kansas
  • Amazon takes on another industry: robotics
    • On the Floor
  • Advertisers
    • PR Submissions
