The relay contacts on Weidmuller’s RIDERSERIES II relay modules can switch loads to 16A at 24 Vdc or 230 Vac for power or signal switching. Base sockets are a push-in connection type to reduce installation time.
Heavy-duty industrial pins nearly eliminate accidental pin bending. Integrated status-LED and diode circuit protect controllers from inductive kick back damage. They also make troubleshooting instant and easy. A relay test lever lets the operator test the output circuit without energizing the coil. The lever can either temporarily or continuously lock contacts closed to allow for hands free testing.
All relays in the series have regulatory approvals, including CE and cURus.
Weidmuller
821 Southlake Blvd.
Richmond, Virginia 23236
Tel: (804) 794-2877
Fax: (804) 379-2593
Web: www.weidmuller.com
About Weidmuller
Weidmuller is a leading supplier of control and automation connectivity solutions such as Industrial Ethernet Solutions, Power Delivery Solutions, Design-Build-Deliver Solutions, Complete Rail Solutions, switching technology for control panels, printed circuit board terminals and connectors, and terminal blocks.
:: Design World ::
Filed Under: MECHANICAL POWER TRANSMISSION, Relays, Terminal blocks
