Inline Modular Bus Coupler and Backplane Expansion Module
By Design World Staff | February 11, 2008
A Modbus RTU/ASCII TCP/UDP bus coupler has eight digital inputs, four digital outputs, a built-in Ethernet switch, and an RS-485 D-SUB connection for Modbus communications. The coupler uses BootP to assign IP addresses. It is 80 mm wide.
A backplane expansion module expands the local bus onto a second rail within the control cabinet. It has a maximum capacity of 63 devices for multiple expansions on a single bus station.  An incorporated power terminal supplies all 24 Vdc voltages required for the low-level signal of an Inline station.
Phoenix Contact, Inc.
www.phoenixcon.com
: Design World :
Filed Under: Connectors (electrical) • crimp technologies
