Innovasic Launches 3-Port Industrial Ethernet Switch with Device Level Ring
By Editor | October 11, 2012
Innovasic announces it has launched the fido2100, a new Industrial Ethernet switch for high performance Device Level Ring (DLR) networks.  DLR beacon rates down to 100 µs support fault recovery and ring restore times of less than 10 ms. A host processor connects to one of the three switch ports via MII for Ethernet communication and to a processor bus for configuration and status.  A C library support package simplifies integration of the switch to any type of processor.
The fido2100 is an IEEE 802.3 standard compliant, Layer 2 switch that is compatible with the IEEE 802.1D standard.  In addition to supporting rings, the switch also supports star, line, and tree topologies.  It utilizes cut through forwarding to swiftly pass traffic from one port to the other port to minimize packet delay.
fido2100-press-graphic
The fido2100 also supports IEEE 1588 v2 Precision Time Protocol (PTP) and supports both ordinary and transparent clocks.  Either ordinary master or slave clock can be implemented on an end device, and the transparent clock has a resolution of 5 ns.  Two inputs to the switch allow external events to be synchronized to system time, and one output provides a pulse-per-second time base.  Third-party PTP stacks can be used with the switch, and there is a C Library available that supports CIPSync.
Innovasic, Inc.
www.innovasic.com
Filed Under: Ethernet — cables • hubs • switches, Networks • connectivity • fieldbuses
Tagged With: innovasic
MTConnect Institute releases Version 2.0 of the MTConnect Standard
OPC UA
Everything is moving – OPC UA Companion Specification “Global Positioning”
Single common conformance test plan to be available for the IEC/IEEE 60802 TSN profile for industrial automation
Ethernet/IP Network specification complete for Ethernet-Apl physical layer for process automation
