Innovative Touch-safe Cover for 10.3×38 Fuses
By Garrett Harmon | June 10, 2014
SCHURTER is pleased to introduce the ESO 10.3×38 touch-safe fuse cover designed to safely and securely insert and extract 10.3×38 mm fuses. After inserting the ESO 10.3×38 with captive fuse into the fuse clips, the complete installation provides a touch-safe cover according to IP20 specifications; additionally the cover serves to extract a blown fuse. No additional tools are required.
The ESO 10.3×38 touch-safe fuse cover, together with SCHURTER’s CSO fuse clips and ASO 10.3×38 mm fuse, is ideal for use in photovoltaic applications up to [email protected] VDC. Specific applications include solar inverters, string fuse boxes, battery charge controllers and numerous applications in the energy and industrial sectors. The ESO 10.3×38 and SCHURTER CSO fuse clips can be used up to 32 A at 1500 VAC/VDC with industry standard 10.3×38 midget size fuses. When using the ESO 10.3×38 with SCHURTER’s CSO fuse clips, the combination carries cURus certification. A legend can be applied to the cover for string or other fuse identification. The ASO 10.3×3 midget fuse meets UL 2579 and IEC 60269-6 photovoltaic standards. Rated current ranges from 1-30 A and rated voltage is 1000 VDC.
ESO-PCB-426x315
Schurter
www.schurterinc.com
Filed Under: Fuses
Tagged With: Schurter
Mersen’s low voltage UL/CSA fuses available at Heilind Electronics
Bel Fuse-Circuit Protection announces new 0ADHC series fuses for DMI applications
Compact distributor for wires up to 500 mm² and 1100 A
Bel Fuse-Circuit Protection announces new 0ADA Series fuses in both ceramic cartridge and pigtail, axial leaded options
