OKW’s EVOTEC designer desktop plastic enclosures are available in a larger 250 size.
EVOTEC is designed for tough working environments. Applications include measurement and control engineering, IT, medical, laboratory and environmental technology. EVOTEC can also be wall mounted for access control.
These robust enclosures feature elegant and ergonomic soft contours that make them comfortable to use. They are molded from ASA+PC-FR (UL 94 V-0) for enhanced UV stability and can be specified with optional IP 65 rated sealing.
There are three variants: Version I has a flat top with a large operating area for switches, push buttons and touch displays. Version II features a smooth sloping top inclined at 12° for desktop applications. Version III also has a sloping top but is recessed to accommodate a membrane keypad or product label.
All three versions have PCB screw pillars in the top and base. Six self-adhesive rubber feet ensure stable positioning on flat surfaces. Torx assembly screws prevent tampering – making the enclosures perfect for medical electronics.
EVOTEC is available in two plan sizes (7.87” x 4.88” and now 9.84” x 6.10”) and in one standard color: off white (RAL 9002). Prices start at $26.
Accessories include an IP 65 seal, a wall mounting kit and self-tapping screws for installing PCBs.
OKW can supply EVOTEC fully customized on request. Services include: custom colors, RFI/EMI shielding; CNC machining; lacquering; water transfer, tampo or digital printing of legends and logos; installation and assembly of accessories.
