Instrumentation tube fittings now ASTM F1387 certified
By Hilary Crisan | January 12, 2016
Brennan’s entire instrumentation tube fittings line is now ASTM F1387 certified. The fittings have passed rigorous testing including pneumatic proof, hydrostatic proof, impulse, flex fatigue, tensile, burst, repeated assembly, thermal cycling, elevated temperature soak and vibration testing.INS-Tube-Fittings
This means that Brennan instrumentation fittings are proven to perform under the toughest conditions without leaks or failures.
Ask a local distributor about Brennan’s complete line of single and double ferrule instrumentation fittings, instrumentation valves and clamps. The instrumentation fittings are interchangeable and intermixable with competitor brands, making it easier than ever to switch.
Brennan products are now registered with CRN numbers in all Canadian Provinces.
Brennan
brennaninc.com
The post Instrumentation tube fittings now ASTM F1387 certified appeared first on Hose Assembly Tips.
Filed Under: Hose Assembly Tips
Tagged With: brennan
single-cover-small-232x300
Midland Metal launches updated 2017 catalog
nfpa
NFPA hosting Chicago Regional Meeting on December 7
RYCO Hydraulics debuts 24-7 program in Houston
NAHAD’s charitable water cause surpasses $10,000 mark
