Insulation fasteners for welding
By Michelle Froese | May 15, 2023
To download, Delta’s Insulation Fasteners Catalog, please click here.
Delta Stud Weld provides high-quality, durable refractory anchors and studs to fit specific needs. The company also offers insulation fasteners, which are special pins used to install insulation on the inside or outside of furnace shells.
Insulation pins are typically applied with welding equipment. These fasteners secure insulation inside steel buildings and are attached to cloth seals, which are used to secure and protect sensitive equipment from heat.
Delta Stud Welds offers insulation fasteners in several types, including cup head weld pins, double-pointed pins, self-locking washers with speed clips, lasing anchors, adhesive, and non-adhesive backed pins. These fasteners are also available in different grades of steel, ranging from mild/carbon to stainless steel depending on the application.
Click here to learn more or to ask Delta Stud Weld a question.
Filed Under: Fastener pins
Tagged With: deltastudweld
