Integrated current sensors measure 100 A and 1000 A, product digital outputs
By Redding Traiger | November 4, 2025
Bourns, Inc. announced its SSD-1000A Digital Current Sensor Series. Highly integrated and compact, Bourns new shunt-based current sensors feature a current range from 100 A to 1000 A and offer exceptional accuracy, stability, and electrical isolation in a wide -40° C to +115° C operating temperature range. These features are required in a broad range of applications, including battery management systems, renewable energy, motor drives, EV charging stations, and other designs that are required to operate in certain harsh environments.
The series’ 16-bit Microcontroller Unit (MCU) delivers ±0.1 percent full-scale accuracy that contributes to more efficient use of power. The internal 24-bit Analog-to-Digital Converter (ADC) provides plug-and-play simplicity, helping to significantly streamline implementation. This enables engineers to quickly add high-accuracy current measurement into their latest designs or retrofit existing ones. There are two SSD-1000A series models: an RS-485 serial interface model, which can also be configured as MODBUS RTU, and a customizable CANbus model. To further help simplify circuit design, Bourns is also offering an internal 120 ohm termination resistor as an optional feature with this new series.
The Bourns SSD-1000A Digital Current Sensor Series is available now and is RoHS* compliant.
Filed Under: Automotive, Sensor Tips, SENSORS
Tagged With: bourns
