    • Subscribe!
Integrated drive for OEM pumps
By Frank Tobe | May 12, 2014
Watson-MarlowOne way to bring products to market faster is through the use of combined systems, such as the DriveSure, a panel-mount OEM brushless DC gear motor with integrated speed controller. It is an adaptable drive for biopharmaceutical, medical device, and process analysis equipment.
DriveSure features a 51:1 control ratio and a 408-8 rpm speed range. The adaptable drive is offered in 24 V and 48 VDC options, and directly accepts market-standard analogue control signals. It features a range of panel-mount brushless DC motor gearboxes and controllers as a package, for those wishing to panel-mount Watson-Marlow’s pump heads, including the 102R, 114, 313D, 501RL and 520R series, for a flow range from 0.1 to 6100 ml/min.
The compact, lightweight and well-balanced design is a ‘plug-in and forget’ approach. The use of Watson-Marlow’s gearbox ensures excellent torque and silent running for the life science and biopharmaceutical sectors, including dental, endoscopy, and in-vitro diagnostics. The comprehensive control and flow rate capability also meets the requirements of bioreactors, bench-top cross-flow filtration and chromatography equipment.
Watson-Marlow
www.watson-marlow.com
Filed Under: TECHNOLOGIES + PRODUCTS, Design World articles, Drives (dc), Motors (gearmotors)
Tagged With: watsonmarlow
Softing introduces OPC UA-based OT/IT integration solution with MQTT connection
Southco introduces stylish corrosion-resistant stainless steel positioning hinge
CIT
Relays feature 1.8-mm contact gap to meet IEC safety standards
New economical linear modules for lighter loads
    • Subscribe!
