Integrated UMR-TRA XY Stages from Newport
By Miles Budimir | May 11, 2010
Irvine, CA – Newport Corporation announces the UMR-TRA XY Stages. The new line of integrated XY stages are built from reliable, industry-standard UMR linear stages and TRA actuators. Affordable and compact, the small footprint measures only 90 mm wide and 38 mm high, including the base plate. The UMR-TRA-XY stages are specially designed for applications in confined spaces, making them an excellent choice for a wide range of motion control tasks in research and industry.
Newport-UMR-TRA-XY-Stages
The UMR-TRA has 12.5mm travel and is available in English or metric versions, DC or stepper motor, and a vacuum-compatible stepper-motor version which is compatible down to 10-6 hPa. For research, the stage is ideal for use in vacuum applications and other space-restricted setups. For industrial applications, the robust stage is qualified for laser beam positioning and can withstand high machine accelerations. The UMR-TRA is compatible with all of Newport’s popular motion controllers, from the hand-held NewStep™ single-axis stepper-motor controller, to the sophisticated and high performance XPS universal controller.
Newport Corporation
www.newport.com/UMR-TRA
Filed Under: Linear motion • slides, Motion control • motor controls, Stages • gantries
49503-ACS Motion-CMxa
SDP-SI-040
PACMotion-servos
