Intel unveiled its 8 million-neuron neuromorphic system codenamed Pohoiki Beach today at the Defense Advanced Research Projects Agency (DARPA) Electronics Resurgence Initiative in Detroit. Consisting of 64 Loihi research chips, Intel claims Pohoiki Beach can be up to 1,000 times faster and 10,000 times more efficient than CPUs for autonomous driving, robotics and other applications.
The 128-core, 14-nanometer Loihi neuromorphic chips, which Intel first detailed in October 2017, have a 60-millimeter die size and contain over 2 billion transistors, 130,000 artificial neurons, and 130 million synapses. Intel said Pohoiki Beach can help scale up neural-inspired algorithms such as simultaneous localization and mapping (SLAM) and indoor mapping for robots.
Intel defines neuromorphic computing as computing that emulates the neural structure of the brain, which can apply principles of common sense and context and deal with uncertainty, ambiguity and contradiction.
“We are impressed with the early results demonstrated as we scale Loihi to create more powerful neuromorphic systems,” said Rich Uhlig, managing director of Intel Labs. “Pohoiki Beach will now be available to more than 60 ecosystem partners, who will use this specialized system to solve complex, compute-intensive problems.”
Some examples of how researchers are using the Pohoiki Beach include:
- Providing adaptation capabilities to the AMPRO prosthetic leg
- Object tracking using emerging event-based cameras
- Automating a foosball table with neuromorphic sensing and control
- Learning to control a linear inverted pendulum
- Inferring tactile input to the electronic skin of an iCub robot
“With the Loihi chip we’ve been able to demonstrate 109 times lower power consumption running a real-time deep learning benchmark compared to a GPU, and 5 times lower power consumption compared to specialized IoT inference hardware,” said Chris Eliasmith, co-CEO of Applied Brain Research and professor at University of Waterloo. “Even better, as we scale the network up by 50 times, Loihi maintains real-time performance results and uses only 30 percent more power, whereas the IoT hardware uses 500 percent more power and is no longer real-time.”
“Loihi allowed us to realize a spiking neural network that imitates the brain’s underlying neural representations and behavior. The SLAM solution emerged as a property of the network’s structure. We benchmarked the Loihi-run network and found it to be equally accurate while consuming 100 times less energy than a widely used CPU-run SLAM method for mobile robots,” professor Konstantinos Michmizos of Rutgers University.
Intel said it plans to introduce later in 2019 an even larger Loihi system named Pohoiki Springs. This version will build on the Pohoiki Beach architecture to deliver even more performance (up to 100 million neurons) and efficiency.
Filed Under: Aerospace + defense, The Robot Report
