The ADAM-6200 Series Ethernet based remote I/O modules distribute control capabilities with peer-to-peer communication and Graphic Condition Logic (GCL) programmability for control within the module or between modules. The peer-to-peer communication is enhanced with a switch and two RJ-45 10/100 Ethernet ports in each module supporting daisy chain connectivity. The internal switch has a physical auto-bypass feature, which ensures continuity of the network should the module fail. The modules are compatible with Modbus/TCP and UDP protocols. Features include hosting an enhanced web page using HTML5, which can be modified and is programmable using Java, JavaScript, and REST.
Advantech Corporation
www.advantech.com/ea
Filed Under: Ethernet — cables • hubs • switches, I/O modules, MOTION CONTROL
