VRmagic offers a new intelligent camera that is perfectly suited for applications in industrial environments, the VRmIC3 OEM. The camera features a wide range of interfaces and an industry-compliant 12-48 V DC wide-range power input with overvoltage and reverse polarity protection. Based on the powerful D3 intelligent camera platform, applications in quality control, surface inspection, or assembly inspection can be implemented easily.
The D3 intelligent camera platform features a 1GHz ARM-Cortex-A8-RISC MPU with floating point unit (FPU) running Ubuntu Linux and a 700 MHz C674x VLIW DSP with FPU. 2 GB DDR3-800 RAM and 16 GB Flash on-board are available as memory.
The VRmIC3 OEM comes with a large number of interfaces like Gigabit Ethernet, Power over Ethernet, USB 2.0 Host, and RS232. Furthermore, it has a compact design with a single main board and a separate sensor board. The VRmIC3 OEM is available as single-sensor camera and as remote-sensor camera. In addition to the OEM product there are also versions with S-Mount and C-Mount lens holders.
“In an industrial environment, an embedded system needs to communicate with other devices within the production process in a variety of ways,” said Oliver Menken, Director of VRmagic Imaging. “With its broad range of industry-optimized interfaces, the VRmIC3 OEM is optimized for the flexible and cost-effective connection to the process peripherals. This way it ensures that customers can implement reliable and economic applications in the field of automation and measurement technology.”
A large portfolio of image processing software is available for application developers. The D3 intelligent platform supports complex programming libraries like Common Vision Blox Embedded and HALCON Embedded, easy-to-use image processing software like Eye Vision, and the open source program library OpneCV. The D3 is also compatible with GStreamer, Qt, TI DSP Codecs, TI IMGLIB and VM_LIB.
VRmagic
www.vrmagic.com
Filed Under: Sensor Tips
