Interchangeable Insert Ratchet Wrenches
By Design World Staff | November 24, 2008
NEW BERLIN, WI — J. W. Winco, Inc. announced it now offers GN 316 series Interchangeable Insert Ratchet Wrenches with a reversing lever.
Made of steel and available in metric sizes, these RoHS-compliant
Ratchet Wrenches are ideal for assembly and repair work, as well as fixed applications on machinery and equipment. The housing of the wrench is coated with black matte plastic in a textured finish. The knob is made of glass fiber-reinforced polyamide technopolymer.
Ratchet Wrenches are available in tapped insert type, round bore with keyway, and square bore type. The inserts are easily interchangeable and can be supplied individually upon request. For certain minimum quantities, hexagon and modified inserts with inch size threads, round bores with keyway, and square holes are available. Other handle lengths are offered upon request.
www.jwwinco.com
Filed Under: Fastening + joining • locks • latches • pins
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
Omron D41D high-coded non-contact door switch for safeguarding machine tools and robotic cells
