Intermediate Coupling Spacers
By Leslie Langnau | July 15, 2012
Coupling Tips
SERVOMAX elastomer couplings feature a specially calibrated polyurethane insert, which is preloaded between precision machined driving jaws. They have high torque density, are low in cost, and are used for vibration damping, shock absorption, and compensation for some small amounts of shaft misalignment. Occasionally, machine layouts and mounting arrangements simply do not allow for installers to achieve the alignment specifications of the standard series. This can cause stress to be transferred across the coupling and insert and onto adjacent shaft bearings, leading to premature wear. For these situations R+W offers the EKZ intermediate spacers for use in high misalignment applications. Since parallel shaft misalignment is compensated for by an angular flex across each insert, the tolerance is actually increased by more than double with the EKZ spacer, in some cases allowing for 4-5x more offset than with single insert designs. Even larger amounts of misalignment can be compensated for with a special convex tooth insert, which allows for additional rolling action as the coupling jaw pivots over the insert rather than causing it to flex. The standard EKZ product line ships from stock and is available in 9 sizes, with torque ratings from 0.5 up to 2,150Nm. They can fit any style of R+W SERVOMAX elastomer jaw coupling of the corresponding size.
R+W America
www.rw-america.com/products/elastomer_couplings/ekz/index.php
Filed Under: Coupling Tips, Bearings
PTDA: Understanding customer use of PT/MC products
Miki Pulley “Sliced” ASK Couplings compensate for all types of misalignment
PT WORK Force introduces new resources to support PT/MC employers
Nearly $120,000 raised in first stage of PTDA Foundation’s Fundraising Campaign
Going small with 3D printing
