Global interoperability solution leader, International TechneGroup Incorporated (ITI), introduces the CADfixTM Plant & Process Simplification (PPS) software solution. CADfixTM PPS is a new, user-friendly solution – built on a proven CAD model translation, repair, healing, defeaturing and simplification platform – to help plant and process design engineers achieve up to 70% reduction in engineering design labor and costs associated with large MCAD model simplification.
Plant and construction layouts include multiple complex machines and large equipment installations. CAD models of these equipment installations contain much more detail than is needed in the full plant layout. Since field users often receive data over cellular connections, large files are costly and slow. In addition, equipment providers who are contracted to deliver files often want to protect their intellectual property. CADfixTM PPS enables engineers to easily and quickly simplify large CAD assemblies for more efficient integration into their plant design systems.
Automatic hidden internal detail removal offers significant data reductions
“Quickly removing unwanted parts or details and simplifying others allows seamless incorporation of equipment models into the overall plant layout and easier file sharing,” stated Andy Chinn, Commercial Director at ITI UK’s CADfixTM development office. “CADfixTM PPS users will experience fast model processing, high levels of data reduction and significantly smaller files. This leads to productivity improvements that are critical to meeting deadlines, achieving profit targets, and moving to commissioning faster.”
Plant designers with little or no MCAD modelling experience can quickly and easily simplify complex parts.
“For the plant and process industry, the holy grail of project management is avoiding project delays and financial penalties. Not only can companies achieve file simplification and integration efficiencies with CADfixTM PPS, but they also have an easy-to-use solution which helps them achieve early project completion,” added Jamie Flerlage, EVP Global Business Development, ITI. “Once the data is simplified, it can be reused in most plant design systems. In that sense, customers can use CADfixTM PPS to simplify the data once and then reuse it multiple times across multiple platforms.”
Tom Gregory, CEO, ITI, added, “The timing of the CADfixTM PPS launch is ideal. While U.S. construction spending projections for the power and manufacturing industries are optimistic and trending upwards, there will be continued pressure for productivity and profitability. Using CADfixTM PPS, our customers are able to get to commissioning faster and can more easily achieve both financial targets and timeline goals.”
CADfixTM PPS simplification tools can be run in an automated batch process or with manual user interaction. General operations can be run using the “wizard” in the automated environment, with manual interaction when the user requires greater control of the simplification process. The rapid internal detail removal is especially helpful for complex assemblies that are fully enclosed within cabinets, and where only the key locating and connecting points are required. CADfixTM also allows for quick identification and removal of unwanted small details such as nuts, bolts, washers and other small parts unnecessary for full plant layout.
The power of using CADfixTM PPS is in the simplification of large CAD assemblies for integration into plant and process design systems, where productivity improvements make a real difference. “When you use CADfixTM PPS to reduce file sizes you can eliminate import failures, avoid CAD rework and deviation potential, gain greater stability and usability of plant and process systems with large equipment models integrated, and reduce lead times,” added Chinn.
For a limited time, ITI is offering a complimentary software trial of CADfixTM PPS. Contact us for details.
Filed Under: 3D CAD World
